12-26-2012 06:13 PM
Dear Sir/Madam,
I just upgraded from RV-042 to RV-042G on 24.Dec.
My previous connections are : (1st) 100Mbps ISP connection, (2nd) 200Mbps ISP connection (fibre to home)
Before upgrade, my RV-042 worked very stable.
After using Migration Tools by exporting RV-042 current config and converted to V3 configuration, the converted configuration was imported to RV-042G.
In the beginning, the RV-042G woks fine after imported converted configuration file. Unfortunately, after around 1 hour of use, my iPad (through an Apple Airport Extreme Station) and wired PC could not browse internet.
But, port-forward to 3 IP-cam still be able to access by my iPhon4 through Carrier 3G connections.
After a reboot of RV-042G, internet connetion comes back. But, after an hour of use, the same issue happened again.
RV-042G makes me fructuated. I will fallback to RV-042 from now on and wait for any futher firmware improvement from Cisco/Linksys.
p/s: my previous RV-042 and current RV-042G config:-
* WAN1 : 100Mbps ISP connection
* WAN2 : 1Gbips ISP connection ( 200Mbps max throughput)
* LAN1 : connected to Apple Airport Extreme
* LAN2 : connected to Linksys 16-port FastEthernet switch
* LAN3 : idle
* LAN4 : connected to an Intel i7 PC
* Dual WAN link mode with bandwidth management, all internet connection from PC will stick on WAN2
Tom Chan
01-03-2013 12:20 PM
Good afternoon
Thanks for using our forum
Hi Tom, my name is Johnnatan and I am part of the Small business Support community. Sometimes you have to do a factory reset to your device after you upgrade your firmware (always make a back up of your data.), you can do that and if the problem persists please let me know and I´ll help you.
I hope you find this answer useful, *Please mark the question as Answered or rate the answer so other will know when an answer has been found.
Greetings,
Johnnatan Rodriguez Miranda.
Cisco network support engineer.
01-07-2013 01:07 AM
Dear Johnnatan,
I upgraded the firwmare and the device could not boot up after firmware upgrade. It seems that the firmware was corrupted
Finally, I returned the RV-042G back to reseller for money back.
Thanks.
Tom Chan
