04-01-2011 02:48 PM
I have two LANs 192.168.0.* and 192.168.1.* (main)
I'd like to facilitate port forwarding on the sub-LAN - is there a way to configure the device to do so? The "main" LANs fowarding works just fine, however I have specific ports that need to go to the sub-LAN. Suggestions? Thanks!
04-04-2011 12:41 PM
IT DEPT,
Actually you can do a port forward to the sub-networks you have configured on the router.
Go to the UPNP tab on the routers setup page and create a custom port forward rule there and manually put in the address of the sub-network.
You can also use this option to do external to internal port forwarding.
02-11-2012 09:13 AM
Forgot to thank you for this post (thank you).
I'm also struggling with trying to separate the two LANs - I would like NO traffic between 192.168.0.* and 192.168.1.*
What would be the most effcient way to do so?
02-11-2012 01:55 PM
Hello IT Dept,
To prevent access from/to each of the networks you will need to configure a firewall access rule to block that traffic.
Hope this helps.
-john
