RV016 (V3) tcp and udp outgoing traffic issue
NICOLAS VENIEL
Hi everyone.
I've got a CISCO RV016 connected to a tooway SAT modem and need  to reach another router connected in DSL
I need to make a TCP connection on port 8080 with my audio codec to reach the other side, and get audio.
I do not feel comfortable with all the security process, firewall, forwarding port and so on ...
What do I need to do to make the RV016 let the TCP out ?
do I need to create rules ?  do I need to modify the firewall factory settings ?
does UDP outgoing traffic need some rules too ?
Thank's for your help.
Nicolas.
System Information
Serial Number :  NKS16450006
Firmware Version :  v4.2.1.02 (Jan 18 2012 14:10:55)
PID VID :  RV016 V03
Firmware MD5 Checksum :  a9817f2dbdcbd6a5c109eaa21b1c3545
LAN  Working Mode :  Gateway
jonatrod
Level 7
Level 7
Hi Nicolas, thank you for using our forum, my name is Johnnatan I am part of the Small business Support community. If you want other method instead forwarding I could advise you One-to-one NAT. I will share a document to you regarding this configuration.
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=544
I hope you find this answer useful
“Please rate useful posts so other users can benefit from it”
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
