RV016 VLAN
myoungohara
Have the Cisco RV016. One single internet access on WAN1. LAN1 connected to a 24-port ethernet switch. Connected to LAN8 is our customer wifi access unit. To separate the public wifi, I set LAN8 to VLAN2. LAN1 is set to VLAN1. How can I set this router to let me access from a computer on the LAN1 (VLAN1) to the Wifi Unit on LAN8 (Vlan2). This configuration has successfully kept the public out of the company network, but has resulted in no access for me to the wifi unit for administration from my desktop.
Mike
Tom Watts
This unit supports port base vlan, it won't route the vlan's between. The router does not support 802.1q nor does it support SVI.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Thanks Tom. I had a suspicion. Best to know for sure. I will likely just change the VLAN to one when we need remote access to the Wifi once every few months.
Thanks again.
