RV042 DMZ
siva.softpath
i am using RV042 router, i have configured DMZ in this,  DMZ is not passing the traffic, i am able to ping the DMZ ip from the server. but the server is not getting the Internet.
Can someone help me what would be the problem.
Siva
blwright
Siva,
First check to verify the default gateway of the server. Because you are experiencing a user specific issue I would suggest calling 1.866.606.1866 and creating a support ticket. Hope this helps.
Blake Wright
Cisco SBSC Network Engineer
