RV082 2 lan, 2 DHCP, 2 external IP
ceslko1980
Hallo to all,
I have Cisco router RV082 and I need to set up in this way. Ther should be two sunbnets.. each should have it´s  own DHCP and each subnet should work in different external IP.. (one Internet port a and second DMZ/internet port)
Is it possible to set up? Can you help me?
Thank you very much...
Te-Kai Liu
Level 7
Level 7
The build-in DHCP Server of RV0xx supports only one IP subnet.
thank you .. that is what I din´t want to read..... :-(
It is possible for you to you use the VLAN functionality to seperate the subnets. Just have a DHCP server on both ends and disable the built-in one. Use traffic routing ot relocate the traffic from VLAN to WAN (by IP ranges).
