RV042 Timeout
cdavis821
I have an RV042 that has recently started causing problems with ActiveSync and my Droid with Touchdown.  ActiveSync is throwing the following event:
Event Type: Warning
Event Source: Server ActiveSync
Event Category: None
Event ID: 3033
Date:  11/23/2010
Time:  2:01:21 AM
User:  DOMAINNAME\User
Computer: MONSTER
Description:
The average of the most recent [200] heartbeat intervals used by clients is less than or equal to [540].  Make sure that your firewall configuration is set to work correctly with Exchange ActiveSync and direct push technology. Specifically, make sure that your firewall is configured so that requests to Exchange ActiveSync do not expire before they have the opportunity to be processed.  For more information about how to configure firewall settings when using Exchange ActiveSync, see Microsoft Knowledge Base article 905013, "Enterprise Firewall Configuration for Exchange ActiveSync Direct Push Technology" (http://go.microsoft.com/fwlink/?linkid=3052&kbid=905013). more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
For
The Microsoft link says to change the HTTPS timeout says to lengthen the HTTPS timeout on the router.  From what I've found so far there is no way to do that on the RV042.  Some suggestions say to try changing the MTU which I have experimented with with no luck.  Does anyone have any experience with this or am I stuck upgrading to a better router?
Casey
0 Replies 0
