10-30-2010 12:38 PM
The web ui on my WRV200s (I have about 100 pieces...) intermittently becomes inaccessible. It usually dies within a day or two, but sometimes it will stay up for a couple weeks. The router still responds to pings while in this state and everything else seems to work (including VPN IPSec). When the web ui dies, I have to power cycle the device to get it going again.
Is there a work around to regain access to the web UI remotely? I do not have physical access to the device at all times so power cycling is not a practical solution for me.
Thanks in advance for any information on this issue.
11-24-2010 07:29 AM
I do have the same Issue.
I don't think they support this product no more since the last firmware upgrade 2.0.0.11 and it is from Oct 2009. They don't give us any signs that they are working on a new version.
That router gave me so much trouble that I'm thinking about buying another model more specifically from another brand.
Good Luck and keep us posted if you have any answers
Franck
11-24-2010 03:21 PM
The WRV210 works fine in the same configuration...
.: Nicolas MÉRIAN - nmerian@excium.com :.
EXCIUM
12B Lot la Sagesse
97215 Rivière-Salée
Tél: 0596 686 686
Fax: 0596 686 685
Gsm: 0690 34 68 34
http://www.excium.com
