03-23-2011 12:54 PM
03-24-2011 01:05 AM
Hi rherreraSHC,
Thank you for posting. We will look into these issues and start working toward finding a fix.
03-24-2011 07:03 AM
We have Cisco escalation working on this issue. The port is still being forwarded, but the newer OS version on the device is more secure and is forcing its own certificate to be given out instead of the passing the certificate request through the RV device. Turning off HTTPS tells the RV to ignore certificate requests. The way we can tell the port is still being forwarded is we are getting the IIS webpage errors not the RV webpage. They are working on finding a solution.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
09-13-2011 07:25 PM
I have this problem as well.. only now I'm stuck with nothing and can't get back to the router web pages. How can regain access to them? And please don't tell me I have to reset!
In other words, I disabled remote management -- was getting too much traffic from hackers on the WAN side... but left SSL on. When attempting to connect from a local LAN ip, I get the login prompt, I login, it authenticates, and bam.. blank pages! Arghgh! Please help.
-Steve
09-13-2011 09:30 PM
did you try updating to the latest firmware? it resolved my major problems.
