RV042 Wont load balancing in gateway mode
Hello i have setup RV042 as gateway i have 2 ISP connected
1) 100mbps > DHCP from router
2) 10mbps > Static Live IP
My problem is with this setup i suppose to get bandwidth near 100mbps as i configured 100+10=110 but i only get 90mbps my 2nd connection won't added if i remove connection 1 (100mbps) then my 10mbps connection gets activated and when i remove connection 2 (10mbps) then my 100mbps connection get activated that way it's working perfectly but when i connect both then i get only 90mbps (Its 90mbps b'cz of my connection 1 is 100mbps) so my other line won't utilizing
So please help me out i how properly configure the router as load balncer
6 Replies 6
jigthaku
Thank you for writing to Cisco forums.
Kindly follow the below configuration link to configure load balancing on RV042.
https://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=d297d2890f084031a5e906f24727104c_Set_Up_Dual_WAN_Connections_.xml&pid=2&respid=0&snid=5&dispid=0&cpage=search
Let us know if the issue is still not resolved by contacting our small business  support team.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
No still no luck i have listing here what im setup here
1) 100mbps line - ip 192.168.1.2 (comes from the router which configures with ppoe ) (auto dns)
2) 10mbps lease line Static ip 180.211.99.75 (Dns comes with static ip)
Lan ip address 192.168.0.1
So i have configured it as load balance mod + gateway so when i try to speed test i only getting 90mbps i supposed to get around approx 100-103mbps if i removed 10mbps connection i get speed up to 95mbps if i removed 100mbps i get to speed around 9mbps so switch over is work perfectly but why I'm not getting speed when both are up if both are up I only get speed up to or nearly 90mbps
From the  Source IP and service definition appear fine, however you will want to change the Destination IP to 0.0.0.0 - 0.0.0.0.
If this does not improve your speed, make adjustments using the Bandwidth Management configuration to allocate the maximum upstream/downstream speed allowed by your ISPs to each of the RV042's WAN Interfaces.
Also my both Upstream & Downstream set max bandwidth provided by ISP then
also when i speed test i only get one of the ISP's speed both are active
but in speed test somehow not showing total bandwidth
For your scenario, I would suggest the TTCP throughput test is better choice for between two routers / between two LAN's.
Please find the below link for more information.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094694.shtml
Please rate the helpful posts.
Okay thanks, ill try and let you know
