ā05-04-2018 12:10 AM - edited ā03-21-2019 11:09 AM
Hello i have setup RV042 as gateway i have 2 ISP connected
1) 100mbps > DHCP from router
2) 10mbps > Static Live IP
My problem is with this setup i suppose to get bandwidth near 100mbps as i configured 100+10=110 but i only get 90mbps my 2nd connection won't added if i remove connection 1 (100mbps) then my 10mbps connection gets activated and when i remove connection 2 (10mbps) then my 100mbps connection get activated that way it's working perfectly but when i connect both then i get only 90mbps (Its 90mbps b'cz of my connection 1 is 100mbps) so my other line won't utilizing
So please help me out i how properly configure the router as load balncer
ā05-10-2018 11:34 PM
Thank you for writing to Cisco forums.
Kindly follow the below configuration link to configure load balancing on RV042.
Let us know if the issue is still not resolved by contacting our small business support team.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
ā05-14-2018 03:43 AM
ā07-02-2018 06:38 PM
From the Source IP and service definition appear fine, however you will want to change the Destination IP to 0.0.0.0 - 0.0.0.0.
If this does not improve your speed, make adjustments using the Bandwidth Management configuration to allocate the maximum upstream/downstream speed allowed by your ISPs to each of the RV042's WAN Interfaces.
ā07-02-2018 10:09 PM
ā07-02-2018 10:16 PM
For your scenario, I would suggest the TTCP throughput test is better choice for between two routers / between two LAN's.
Please find the below link for more information.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094694.shtml
Please rate the helpful posts.
ā07-02-2018 10:19 PM
