06-22-2015 03:20 AM
Apparently I did the classic mistake when updating RV042G (V1) firmware. I closed the browser window during the process and now RV042G is bricked.
It responds to ping at 192.168.1.1, but I can not push the correct firmware via TFTP.
Can somebody give a correct procedure for TFTP recovery?
BR,
Markku
06-22-2015 08:33 AM
Try info on this post.
https://supportforums.cisco.com/discussion/12056971/rv042g-v01-crashed-after-firmware-update
06-22-2015 10:00 AM
Thanks Tom.
I saw it earlier. I tried putting firmware to 192.168.1.1 already. It did not succeed.
What I really would like to know:
Is rv042g acting as a tftp server and accepts whatever one puts there. Or is it in tfto client mode looking for a tftp server in known ip address which is offering firmware with fixed filename?
Strange that Cisco has no utility for g series. Only older rv042 series.
BR.
Markku
06-22-2015 05:29 PM
It should be client mode looking to pull the software.
The older versions had the utility that kind of did that for you.
02-23-2016 11:57 AM
I had this problem too with my RV042G, which was just outside the 12 month warranty. However, I did not close the browser window and the process failed when the computer indicated that the router was re-booting.
Cisco could not help and suggested I buy a support contract! Very poor show considering this must be their bug.
All that is actually required is a TFTP client to interact with the router's boot-loader, which is just waiting to help.
Original information for this was found on:
https://tvi.al/fix-the-diag-blinking-led-with-cisco-rv042g-router/#disqus_thread
Many thanks are due to the author!
Also useful reading is:
https://www.dd-wrt.com/wiki/index.php/TFTP_flash
When running on my Mac, the following commands were issued (make sure your computer is on same subnet with an address such as 192.168.1.10 etc):
$tftp
tftp> connect 192.168.1.1
tftp> binary
tftp> put RV0XX-v4.2.3.07-20151008-code.bin
Sent 26284032 bytes in 9.4 seconds
tftp> quit
Make sure the 'DIAG' LED is flashing before you start. Once the tftp transfer is complete, the 'DIAG' LED should light solid while the router programs its flash memory and then reboots. I did have to try twice before the procedure succeeded - just power off the router between attempts.
I hope that this helps prevent your otherwise-good router finding its way to the bin.
Paulppast
05-06-2016 07:54 PM
This process worked for me, thanks Paulppast!
I had to use a windows machine to upload the firmware file, so I had to download a TFTP client. I used TFTPd32 from http://tftpd32.jounin.net/tftpd32_download.html (The page says TFTP Server, but it contains a client as well) .
To others trying this, if you are impatient like me, be sure to give the router time to flash and reboot. It takes 3 - 5 minutes for the process to complete, the DIAG light should be solid amber that whole time, then it will reboot automatically.
05-10-2016 09:13 AM
Thank you for emphasising this, Matthew. The process certainly does take a few minute to complete and it is most important not to interrupt it in anyway until the router re-boots on its own. Otherwise I suspect that you will be back to square one!
05-10-2016 02:24 PM
The TFTP client and link provided by Matthew works great.
After manually setting the iv4
Disabling firewall and pinging the router
Start TFTP software select TFTP Client
05-11-2016 08:59 AM
Thanks Matthew,
After 11 months I finally have bricked RV042G alive again.
It seems that the right TFTP tool was needed. This TFTPd32 (I actually used 64b version) worked. I have tried 2 different TFTP clients during this time but this did the trick.
Thanks again for everyone in this thread.
Markku
