10-12-2012 06:18 AM
Is it possible to create a service which will forward public port 9010 to an internal IP address with port 23 ?
First of all, I do not like to open the public Telnet port to the inside so I would use another public port and second my ISP does not allow some public ports beneath port 80
Thanks for your help
Solved! Go to Solution.
10-12-2012 06:36 AM
Checkout the UPnP forwarding table under the Setup>UPnP tab on the left. Note that UPnP does not have to be enabled for the forwarding rule to function.
10-12-2012 06:36 AM
10-12-2012 06:57 AM
thanks a lot! without this hint I wouldn't have found it.
