RV082, Dual Wan, VPN + Protocol Bindings
b.thibodeau
Hi all,
I have this kind of setup and I can't figure out how this router thinks.
My setup uses Dual Wan in load balancing mode. I only need a single VPN tunnel. High availablity is my concern.
Site 1 has Fiber and Cable
Site 2 has Cable and FTTN
Every ISP supplies Static IPs
VPN works great in the event of an outage. I am still disappointed that it works in case a single primary WAN breaks, but is not operational if primary WAN on Site 1 shutdowns at the same time Site 2 secondary WAN stops. It's a really rare case but could happen.
Anyway, my problems lie where I need Protocol Binding to preserve secure WEB sessions (https, banking, supplier portal).
I have to bind, at least, port 443 to my primary WAN. This way, I can access websites and keep my session active.
Then, if I have to browse a HTTPS server on the other side of the VPN, Protocol Binding still tries to pass port 443 through WAN1. It does not even consider the VPN as a valid route first.
Problem (Maybe)   Can I reduce Hop Count for Site 2 to less than 35??     P.S. I replaced addresses as I do not feel they are revelant.
Destination IP
Subnet Mask
Default Gateway
Hop Count
Interface
WAN2 network addr255.255.255.252*0eth2
WAN1 network addr255.255.255.248*0eth1
Site 2255.255.255.0Site 1 Fiber Gateway35eth1
Site 1255.255.255.0*0eth0
default0.0.0.0Site 1 Fiber WAN115eth1
default0.0.0.0Site 1 Cable WAN240eth2
default0.0.0.0Site 1 Fiber WAN140eth1
Thanks to all,
Bruno
I would conclude that is a bug and requires further investigation. I wouldn't call it a limitation if it were my decision (not that I matter so much in this regard)
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
6 Replies 6
Tom Watts
Hi Bruno, in the event of a WAN failure, the protocol bind rules should be failing over to the other WAN port. That is how the router is intended to work.
If your contention is that it is not happening a few steps to do first to receive proper support-
*Upgrade to the latest firmware
*Factory default the unit
*Create the base configuration
*Test
If this fails under the most fundamental circumstance then it would be a good time to call the small business support center and ask for an investigation.
-Tom
Hi Tom,
Thanks for your insight.
Unfortunately this is not exactly the problem. Failover is OK. Problems lies with Protocol Binding + VPN
Binding a port to a specific WAN connection prevents it from ever going through the VPN tunnel.
i.e.: binding port 80 to wan1 prevents me from accessing a web server in my branch office, even if wan1+2 are operational on each side.
I recently got an answer from support.
Support:
After labbing up the scenario and discussing the case with our SMEs I have determine that there is not a workaround for your particular issue. Unfortunately, when you bind traffic to an interface it does just that. There isn’t a way to bind the traffic but also allow it to go through the VPN tunnel.
Bruno
Hi Bruno, the binding and WAN port must be one in the same, this is correct. If you bind 443 to WAN 2 while the VPN is running on WAN 1, the precedence will remain at WAN 2 for the connection request.
-Tom
I agree with you.
But what if I turn this around?
Let's use the same fact but change it a little bit.
The binding and WAN port must be one in the same, this is correct.
If you bind 443 to WAN 1 while the VPN is running on WAN 1, the precedence will remain at WAN 1 for the connection request.
This is what happens right now. Looking at routes, I thought by logic that would still let VPN route like an internal network, not external or WAN.
Binding a port stops all traffic it may haul from ever reaching this route.
Imagine a single el cheapo router in a 192.168.0/24 subnet with a server at 192.168.0.2
Its like typing a valid web server ip (suppose 192.168.0.2) in your subnet and getting the same error as typing 192.168.254.2 (which is no even there in this scenario).
Looks like it reaches the limits of the router OS
-Tom
Thanks again.
But support cant or wont do much more.
