RV082 IP addresing Class B
pablosorella
I read in the RV082 user manual can I configure a Ip address class C in the LAN interfaces.
I need to know if the router support a class B addressing.
Can anybody help me?
jeffrrod
Level 4
Level 4
Dear Pablo,
Thank you for contacting Cisco Small Business Support Community.
Unfortunately the Small Business RV082 router does not support a class B LAN addressing scheme. However, you can enable multiple subnets to allow this router to work as an edge device that provides Internet connectivity to different subnets in your LAN.  Please refer to the admin guide, p.29;
http://www.cisco.com/en/US/docs/routers/csbr/rv0xx/administration/guide/rv0xx_AG_78-19576.pdf
Please let me know if there is anything I may assist you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
