RV082 NAT to other subnets.
tom
Is it possbile to NAT to other subnets with the RV082. It is on a 192.168.41.x and I have a phone system on a 192.168.20.x. Any way i can do this? After searching all over others are saying no.
mpyhala
Level 7
Level 7
Hi Tom,
Thank you for posting. On the Setup-> Network page you can select Multiple Subnet and add 192.168.20.x to the router.
Yes I see that but I can only add an IP to the router (192.168.20.1 255.255.255.0) I want to add the subnet IE 192.168.20.0 255.255.255.0, without assigning one IP to the router.
Tom,
That is how you add a subnet, by adding an IP to the router. Add 192.168.20.1/24 and the router will have both LAN subnets. You cannot add a subnet without adding an IP to the router.
Please be reminded that additional access rules may be required if you have RV0xx V3 router. Check the firmware release note for details.
