RV082 Router having issues with downloads
veritas247
I have an RV082 and when I download files from the internet, it will stop downloading the file until I stop and resume the download.   It will go for a couple of seconds and then stop.
I have downloaded different files from different urls.   I am sure the issue is not the files or websites I am downloading from.
I tested these same downloads with same computer, from a different physical location and they download file.  Not computer.
I tested download speed with my DSL provider and from bandwidth test sites.  Bandwidth fine.
I hooked directly into the DSL modem and it downloads great.
I hooked into RV082 router with no other devices or computers plugged into it, and that is when i hit the issue.  Must be router.
Can anybody help me trouble shoot this please?
Can I get into the device and pull logs?   I am a new person at the office and helping them try to fix this issue.   Took me hours just to get here with the above tests.
Please help.
daviddun
Level 3
Level 3
What router firmware are you using on the router?
1.0.11 (Jan 16 2004 15:45:58)
thank you for replying.
daviddun
Level 3
Level 3
You need to go to Cisco.com and download the lates version 2.0.0.19 for this router
Hopefully this may fix your issue.
