RV082 VPN problem
zeeshan.ali
I have an RV082 and a RV042. I have been able to successfully establish a gateway to gateway vpn connection between them both, but ooth Routers unable to ping each other and I can't remotely administer each router through the VPN connection.
Please help me if any one have a solution.
jonatrod
Level 7
Level 7
Good morning.
Thanks for using our forum.
Hi Zeeshan Ali  my name is Johnnatan and I am part of the Small business Support community.
In order to resolve your problem , you can follow these two tips:
Step1: Go Firewall > Access rules and check that there is a rule that is blocking any port or some ip address which prevent the Ping or remote access.
Step 2 : Go Firewall > General and disable the “Block Wan Request” and enable the “Remote management” (also you can change this port).
I hope you find this answer useful, if it was satisfactory  for you, please mark the question as Answered.
Please rate post you consider useful.
Greetings,
Johnnatan Rodriguez Miranda.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
