06-30-2013 11:53 PM
Hi all,
I connected different PPTP Client devices to my RV110W (PPTP Server) but the problem is that one connected client cannot "see" another PPTP client.
The setup would be:
PPTP Client A (linux - firewall disabled) connects to RV110W (PPTP Server)
PPTP Client B (iphone) connects to the same RV110W (PPTP Server)
From the iphone i cannot access the website hosted by the linux server.
From a computer in the same VLAN as the PPTP clients i cannot access/ping the linux server
1. Is this a limitation of the RV110W - that PPTP clients cannot "see" eachother, or should i dig deeper with the connected devices?
2. What safe scenario should i use to succesfully test if this works (eg. 2 windows machines connected as PPTP clients and to try to ping eachother)?
3. Is this related to the routing table?
Thanks in advance,
Todd
Solved! Go to Solution.
07-01-2013 03:59 AM
By default the PPTP clients can communicate with each other, as they are in the same LAN
The PPTP server (RV110W) by default is with an IP 10.0.0.1. The clients are provided IP addresses from 10.0.0.10 to 10.0.0.X.
So you should be able to ping the clients on those IP addresses, without any additional configuration on the router
Kremena
07-01-2013 03:59 AM
Kremena
07-03-2013 10:55 AM
If you would like any additional information or more help with your PPTP configuration, you can click the link below. This link will bring you to an article written about how to configure PPTP on an RV110W. Hopefully this can help you solve your issue.
Andrew Mayfield
