RV120W Failed firmware update
monte
i tryed to update my rv120w from 1.0.2.6 to 1.0.4.10
after about 15 minutes i power cycled the router.
it now has alternating green power and wireless lignts flashing and router is unresponsive.
it does not give out ip address and not reachable when seeting static ip on cpu
i have tried the reset button.
Can this unit be recoverd somehow?
Te-Kai Liu
Level 7
Level 7
If you configure your PC to use a static ip, such as 192.168.1.100, and point your web browser at 192.168.1.1, you should be able to see a primitive web page to load the firmware image again.
I was able to upgrade the router and get it working again.
The basic page did load to do the update.
I did try this before but could not access the router, but i do not think the
lights were alternating the flash at that time.
Monte
