RV120W port forwarding not working
nixmartin
Hi!
I have here a RV120W that's behaving quite oddly. From a normal router point of view everything is OK (wired and wireless LAN works, I can access internet, etc.).
Problems started when I wanted to set up port forwarding - requests from the WAN side just time out. Despite the fact that logging was set to "on", there are no lines concering that port forwarding. And I'm 100% sure that this webserver I've used as an example is working correctly.
Next thing I tried was Remote Management. This time it doesn't time out, instead I'll get an empty white page.
I've tried restoring the facotory defaults, firmware is the latest (1.0.1.3). Nothing seems to help.
I'm running out of ideas here...
with greetings,
Martin
qumartin
To fix the remote management problem you need to change the port to
from 8080 to 443 and that should fix the remote mangement problem.
Quendale
