04-03-2015 06:44 PM
My RV130 having laggy GUI response no matter access via LAN, WAN, http, https.
Sometimes it does not response after a moment (not a matter inactivity timer, set to 30 minutes) and required to log-in again.
Is it a bug?
Solved! Go to Solution.
04-06-2015 03:08 PM
Hi Rocky,
these routers are designed for throughput, not for administrative interface performance, but you should not see timeouts,
what firmware are you using? can you update or reflash it with the latest firmware? that would refresh the executable, and all system files.
1.0.1.3 is the latest, here: https://software.cisco.com/download/type.html?mdfid=285026141&i=rm
have you looked at the logging or system summaryto see if there are attacks going on, or high cpu use?
also are there any switches or other routers in your topology that might be impacting this router?
Dan
04-05-2015 04:53 AM
I hope there sesssion_id will appear in the URL such that reloading the page does not require to sign on again.
04-06-2015 03:08 PM
Hi Rocky,
Dan
04-15-2015 10:58 PM
It is found that the CPU load was very high with port based QoS enabled.
I believe this is the cause. I try to turn off QoS and see what happen
05-15-2016 08:08 AM
I have the same issue using the last firmware (1.0.3.14). What are the procedure to disable QoS?
Thks!
