rv130w bandwidth management issue
reflexivo
On our RV130w, under QOS, I enabled Bandwidth Management in order to create a service rule to prioritise VOIP traffic. However, I've noticed that when I do that, the WAN bandwidth is reduced to the internal ports. It seems to be dividing it equally across them, and I'm not clear why. Is there a way to preserve maximum WAN bandwidth on at least one of the ports, while still enabling VOIP prioritisation?
balaji.bandi
what there is remarking YES and NO any reason ?
You need to make a Rule for rest of the traffic and voice, and voice high priority at the same time you need to device what is to be done rest of the traffic ?
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5014-bandwidth-management-on-the-rv130-and-rv130w.html
BB
reflexivo
Thanks - on reflection I don't think bandwidth management is actually needed for VOIP, just applying DSCP, which can be done in other ways.
