RV160 Admin Web UI not showing
ErikG
I just got a RV160. When I access https://192.168.1.1 I initially get the "not secure" Chrome warning. I bypass that but then the page never loads. No sign-in box appear (its just grey). I can view source and there are some minimal access going on (looks like an old angular application) but that's it. Should I return it or is there something I'm missing?
It gets an IP from my ISP, the DHCP is working but I cannot access the web ui.
I've tried resetting, unplugging, waiting 5,10,30s but nothing seems to work.
5 Replies 5
balaji.bandi
Check you have ping working continuously, if the ping ok, then try a different browser.
Try Power off the device and ON and test. ( also let us know what LED you see ?)
BB
I have the same problem. Ping is working, but the web GUI doesn't want to load. I have tried Firefox, Chrome, Edge Nothing helps LEDs PWR and link/act + gigabit light green.
Experiencing the exact same scenario.  Ping works but no GUI access.  Tried all browsers but web page load always fails after the security warning.
Hi ,
My name is Nikola Butlev and I'm a Cisco Engineer,
Have you tried with a different IP address which is to be  set through your PC.
Then type the new IP address in the address bar.
Thank you,
I don't understand. How to change the IP number of the router without having posibility to access it's configuration? Maybe there in another posibility to do it...
