RV180 portforwarding ranges
GeorgeRKroon
Firstly i would like to say that my RV180 works pretty well, not a single problem in setting it up for normal use!
But now I'm trying to get a service working that uses multiple port ranges (gaming server -> BF2) for me and some friends.
When creating a new service on the admininstration interface it is possible to create the ranges it needs to portforward.
But when actually portforwarding, it is only possible to portforward to 1 port (and not the same as it listens on)
I've correctly set up the server to use all default ports
UDP/TCP 1024-1124
UDP 1500-4999
TCP 4711
UDP 17567
UDP/TCP      18000
UDP/TCP      18300
UDP/TCP 27900
UDP 27901
UDP/TCP 29900
Am I doing something wrong or is there a solution to this problem?
George
6 Replies 6
lariasqu
Hi George, thank you for using our forum, my name is Luis I am part of the Small business Support community. I am happy to hear you are satisfied with your RV180, could you please check your configuration with the next article below?
Port Forwarding on the RV180 and RV180W VPN Routers
I hope you find this answer useful
Greetings,
Luis Arias.
Cisco Network Support Engineer.
Hello Luis, I did not read that article before because the interface is clear enough to get things working without help.
The first port I had to forward was 80 and this did work.
The 'problem' I'm having is also shown in this article:
Step 7. In the Internal Port field, enter a port number to which the traffic is forwarded.
The service I am trying to forward is a ranged service (port 1024/1124 for example) so when I configure this service, it forwards all these ports to 1 port (1024 -> the one filled in) on the destination ip.
Thank you for looking in to this,
George Kroon
Hi George,
Create a Custom Service with the port range as follows:
Start Port: 1024
Finish Port: 1124
Create a new Access Rule using the custom service you created:
Connection Type: Inbound (WAN (Internet) > LAN (Local Network)
Action: Always Allow
Service:
Source IP: Any
Send to Local Server (DNAT IP):
Rule Status: Enabled
That should do it. Please reply if you have any questions.
- Marty
Luis,  I am having this same issue.  Was there ever any additional resolution for this?
RV180 can do port range forwarding, please check this steps from this link :  https://supportforums.cisco.com/comment/10095546#comment-10095546
Please rate this post or marked as answered to Help others Cisco Customers
Greetings
Mehdi
Clayton Sill
Hello George,
     This could be causing your issues.
CSCuc72086 Description—Port forwarding in regards to port range does not work.
                    Workaround—Use a single port instead of a port range
Reference here: Release notes: http://www.cisco.com/en/US/docs/routers/csbr/rv180w/release_notes/rv180w_rn_1-0-3-10.pdf
But looks like this bug was carried over from firmware version 1.0.2.6 to 1.0.3.10, heck it could still be a bug in older versions as well.
So probably based on how you have it configured and how Marty recommended how to configure it then this is probably a bug.
What I would do next is call Cisco Small Business support or try and open a chat with them to get them a ticket open for you and report that you are having issue with bug code CSCuc72086. Normally they would probably still do some troubleshooting with you to make sure you have everything configured correcly. Once its confirmed they'll probably try and get the case escalated. Usually a Beta firmware is handed out then at that point if they have gotten a fix for it yet through Beta.
Hope that help you out.
Clayton Sill
