RV180W IPsec tunnel don’t connect automatically after reboot
Alain.Knaepen
I have a cisco RV180W with a IPsec tunnel to the head office. The tunnel is working good, but if I reboot the RV180W, the tunnel don’t reconnect automatically, I need to go in the admin interface to IPsec Connections Status and press on Connect.
Is there a way to make the tunnel connect automatically?
Tom Watts
Hi Alain, you may try to enable dead peer detection
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Dead peer detection is enabled, so that's not the problem.
My memory does not serve me well but if there is a keep-alive option this usually is the toggle for the vpn to reconnect automatically. DPD is similar but not the same.
-Tom
Normally in the cisco vpn routers there is a keep-alive option, but strange enough in the RV180W that option is not available.
