11-13-2013 02:15 AM
in our network we have 3 Servers, 1 Printer, 1 NAS connected wired!
And then there are 5 Notebooks connected wireless!
From the notebooks i can ping every wired device but no wireless device!
Form all wired devices i can ping all devices!
I'm searching now for 4 hours and have not found a solution!
I think something like PSPF is activated but there is no setting in the Webinterface!
CommandLine(Telnet) is not possible!
Please help!
NG Thomas
Solved! Go to Solution.
11-13-2013 05:34 AM
Hello Thomas,
This sounds like "Wireless Isolation within SSID" - has to be disabled.
Check if you are with the latest firmware as well -
Kremena
11-13-2013 05:34 AM
Hello Thomas,
Kremena
11-13-2013 05:44 AM
Hi, thanks for the post!
I have solved the problem now!
This was a Problem with the Webinterface or the firmwareversion!
One of the first things i have checked was "Wireless Isolation within SSID" is disabled! And it was disabled!
So now i have tried to enable it and disbale it afterwards!
By disbaling after enabling first everything works fine!
Thnaks a lot
NG Thomas
