RV220W PSPF ??
thomasschober
in our network we have 3 Servers, 1 Printer, 1 NAS connected wired!
And then there are 5 Notebooks connected wireless!
From the notebooks i can ping every wired device but no wireless device!
Form all wired devices i can ping all devices!
I'm searching now for 4 hours and have not found a solution!
I think something like PSPF is activated but there is no setting in the Webinterface!
CommandLine(Telnet) is not possible!
Please help!
NG Thomas
Kremena Ivanova
Hello Thomas,
This sounds like "Wireless Isolation within SSID" - has to be disabled.
Check if you are with the latest firmware as well -
http://software.cisco.com/download/release.html?mdfid=283118607&softwareid=282487380&release=1.0.4.17&relind=AVAILABLE&rellifecycle=&reltype=latest
Kremena
Kremena Ivanova
Hello Thomas,
Kremena
Hi, thanks for the post!
I have solved the problem now!
This was a Problem with the Webinterface or the firmwareversion!
One of the first things i have checked was "
Wireless Isolation within SSID" is disabled! And it was disabled!
So now i have tried to enable it and disbale it afterwards!
By disbaling after enabling first everything works fine!
Thnaks a lot
NG Thomas
