RV220W suddenly lost QuickVPN connectivity
fdspadm12
RV220W worked good with QuickVPN, but suddenly lost such ability and doesn't allow connection from any Windows machine (Xp,Win7 32/64 bit)
QuickVPN is ver. 1.4.2.1
Cisco RV220W firmware is ver. 1.0.4.17
Client error on Windows XP in Log.txt :
[STATUS]OS Version: Windows XP
[STATUS]Windows Firewall is OFF
[STATUS]One network interface detected with IP address 10.1.1.165
[STATUS]Connecting...
[DEBUG]Input VPN Server Address = x.x.x.x
[STATUS]Connecting to remote gateway with IP address: x.x.x.x
[WARNING]Remote gateway wasn't reached
[WARNING]Failed to connect.
[STATUS]Remote gateway was reached by https ...
vpnserver.conf saved on client, but doesn't have gateway IP details
Cisco router log shows: [IKE] Faild to load the configuration
What has been done on client :
Firewall off
ipsec service is running
antivirus off
netsh int ip reset
allow 1723,500,4500,443,60443 inbound ports on home router
even move client IP to DMZ
remove VPN software other than QuickVPN
https.pem certificate exported from router and put in client directory
What hs been done on Cisco RV220W router:
Networking>WAN>IPv4 WAN: MTU is default (there is now "auto" in RV220W)
Firewall >Access Rules: no forwarding rules for 443,60443,500,4500
Firewall >Attack Prevention (both "enabled" and "disabled" have been tried):
  • Respond to Ping on WAN - enabled
  • Stealth Mode - disabled
  • Flood - disabled
  • Block UDP flood - disabled
  • Block Anonymous ICMP - disabled
  • Block Fragmented Packets - disabled
  • Block Multicast Packets - disabled
VPN>IPsec>VPN users: QuickVPN user created
VPN>VPN Passthrough: ipsec,pptp,l2tp enabled ("disabled" for pptp also has been tried)
Administration>Remote Management on port 60443 - enabled
Thanks for using our forum.
Hi Alexey, my name is Johnnatan and I am part of the Small business Support community. In order to resolve your problem I created a document to help you.When you are configuring a remote VPN connection, there are some steps that are lost on the path. Here you can see those steps. Please read it carefully and if you have any question or doubt please let me know and I´ll help you.
https://supportforums.cisco.com/docs/DOC-29399
I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it".
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
linksysinfo
Level 4
Level 4
HI There,
Welcome to the club.  I too gave up on QVPN on the RV220W. afaik you need the Firewall enabled on the client for IPSec to work correctly (vista/Windows 7)
Can you use SSL VPN?  that what i use now.
Regards Simon
http://www.linksysinfo.org
Regards Simon
Hi Simon,
Currently i struggle with Windows XP
What i have discovered , that QuickVPN is working a little after router reboot , but stops after a few minutes.
SSLVPN has only 10 licenses on RV220W , but i need more (QuickVPN has 25)
Alex
Greetings,
Hi Johnnatan  ,
Finally problem has been solved follow by all suggestions.
I would say Quick VPN installation isn't straight forward and very dependent on
status of OS on specific computer.
Sometimes need to find and remove other 3d party vpn software,reset tcp with netsh,
Alex
