09-11-2021 02:41 AM
My ISP need Loopback interface to be configured on RV260-V2 for ISP side health monitoring. has anyone done it?
Solved! Go to Solution.
09-13-2021 01:46 AM
Both nagrajk and balaji are correct, the loopback interface is not supported on RV160/260/340 series.
09-11-2021 06:29 AM
I do not believe these models support Loopback, never seen any community user used or mentioned use case.
why only loopback, why not use vlan interface?
09-11-2021 12:16 PM
No, Loopback interface is NOT supported on RV160/260/RV34X routers
09-13-2021 01:46 AM
