RV320 and Mac VPN other than pptp, possible?
simon00016
Hi all,
after lots of hours spent trying to setup a secure vpn between my RV320 Cisco Router and my macbook pro, I ended here.
For what it seems, L2tp over Ipsec and even Cisco Ipsec in the default vpn client in the mac are unnable to stablish a tunnel with this router. Am I right? Is there any solution other than use a third party vpn client?
Thanks in advance, Simon.
Marc Nagao
The RV320 can be setup with SSL, IPsec, and PPTP VPN clients.
if you have issues, please set-up a case with our support team and we can help you.
Marc
mpyhala
Level 7
Level 7
Simon,
Have you tried IPSecuritas for Mac? I have used it successfully with other Small Business routers such as the WRV210 and RV220W. It has been a while but as I recall it worked fine.
In this community there is documentation for SA500 which is what I followed to configure the router and client:
https://supportforums.cisco.com/docs/DOC-10279
- Marty
simon00016
Hi all,
we got it using the EasyVPN connection from the router (the only one that worked other than pptp).
Thanks for your help, Simon.
