Rv320 Dual Wan
rwfurlough
I am trying to configure a rv320 dual wan and I am having issues between a cable modem and the router. I am able to get out using obtain an ip but I cannot get to any ports when I try to come in from the outside via the cable modem to the router and to the final destination. I just know enough to screw things up, so any help in English would be greatly appreciated.
balaji.bandi
how is your config look like - when you mentioned Dual wan, do you have Dual ISP connection or single one :
check below document for portfowarding :
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb4159-port-forwarding-and-port-triggering-on-rv320-and-rv325-vpn-r.html
note if the ISP blocking the ports then it wont even reach your router, so check the logs of RV is the packets reaching the router when the connection intiated from outside.
BB
5 Replies 5
balaji.bandi
BB
I have two cable modems with different isp's feeding the RV0320 Dual Wan Router .One modem is in bridge mode
The first time I configed I used static ip for wan1 and obtain for wan2. I was not able to get in or out, so I switch the static to obtain was able to get out but not get in. I set up port forwarding  for port 80 etc  but unable to get  to the IIS server..
Hope this info helps
Do you see any logs on device ? have you checked with ISP ?
BB
I haven't checked the logs but will later as I do not want to take down the IIS server
logs you see on the router, do you see any port forward logs (not on IIS)
anothing do not expose port 80 that is security risk.
BB
