The rv320 (v1.3.1.12) is set up with two different ISP providers - dual wan with load balance (auto mode)
Since yesterday Wan1 (isp1) is very slow to unresponsive, due to maintenance.
The rv320 does not seem to detect the problem.
It almost as if it sees there is no traffic on Wan1 , and consequently pushes everthing to Wan1
As a result, Lan to internet traffic is impossible.
Only I physically remove the Wan1 cable (or turn off the wan1 modem), the Wan2 port is used and internet traffic resumes.
- Is it possible to modify the Rv320 configuration so it detects this type of problem?
In system Management, Dual Wan: Network service detection is enabled (with the defaults) .Default Gateway is set (although I'm not certain what this does)
-Can a Wan connection be disabled from the rv320 configuration ? So I don't have to physically turn off/on the ISP modem.
Suggestions are very welcome
