Bookmark
Subscribe
1484
RV320 lan to lan VPN setup for Draytek
qube00001
Hello Cisco freaks
I am trying to connect a branch office network (Cisco RV320 router) with our other branches Drayteks (2820, 2950, 3900). Both devices look to support common settings but fails to connect. Triple checked all settings, Tried all possible SA, key and encryptions combination to no avail. I am familiar with VPN issues but this time I can not figure out what's wrong. The RV320 syslog does not output enough VPN log to troubleshoot.
  • checklist :
  • differents LAN's
  • consitent phases setting on both devices, tested all groups, hashes and encryptions
  • correct routes and interfaces
  • local security group : subnet
  • using PFS did not help
  • no idea if the "AH Hash Algorithm" needs to be checked, tried all anyway
does the Cisco uses ESP or AH protocol? this may be worth to know
Is the IPsec implementation of Cisco compatible with Drayteks?
Did somebody ever managed to connect those 2 devices?
qube00001
Ok, I got it working
I managed to connect a cisco RV320 with drayteks (3900, 2820, 2925) using lan to lan VPN.
It was very hard to troubleshoot as the cisco doesn't output VPN logs unless you are successfully connected :-/
I used draytek's log and found a netmask issue. Now it works
For the record here is my working setup
Group 5
AES128
SHA1 withauth
no PFS
ESP (uncheck AH on the cisco uses ESP)
higher settings may work, not tested
Can you attach snapshots from both routers regarding VPN site to site setup.
BR,
Pedro
