07-20-2013 12:27 PM
Can anyone provide me a link to the manual for the RV320?
I've found manuals for a number of the other RV routers, but can't find the RV320.
Thanks.
07-21-2013 06:31 AM
Hello Peter,
I have given the link for the manual below:
http://www.cisco.com/en/US/docs/routers/csbr/rv320/quick_start/rv320_qsg_en.pdf
Please let me know if you need further help.
07-21-2013 06:44 AM
Hello Peter,
The above one is a quick start guide. However, there are further documentations. Please click the below link and choose Routers in the Products drop-down menu. Then after choose RV320. You will find all the documentation related to RV320 configurations:
http://sbkb.cisco.com/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=
Vijay
07-21-2013 12:11 PM
Hi McWilliams,
Please refer to the link below to know details about RV320 which includes datasheet, product imagery, product overview with comparison with other routers.
http://www.ciscosblaunchpad.com/rv320-dual-gigabit-wan-vpn-router
Thank you.
07-24-2013 02:43 AM
As these employees should have seen if they had checked the links they provided there is no manual (yet) for the RV320.
The information from Vijay get's close (and should be usefull) but it's still not a manual...
07-26-2013 11:47 AM
Hello Peter/Servaas,
Please refer the link below for RV320 admin guide.
http://www.cisco.com/en/US/docs/routers/csbr/rv320/administration/guide/en/rv32x_ag_en.pdf
Thank you for your patience,
Hope this helps,
Vijay
Please rate useful posts.
