RV320 massive SYN Flooding attacks?
martinmpet
I have purchased a RV320 small business router for my home office, but i am experiencing massive SYN Flooding attacks when clients connect to my ftp and when rsync backup is performed.
My equipment consists of
Cisco RV320 Router running v1.1.0.09 (2013-07-04, 13:28:17) FW
Synology DS212 Nas
Setup
Cisco RV320 Router with static IP 192.168.1.1
WAN1 is used and configured with an static WAN IP
DHCP Range from 192.168.1.100 to 149
Port Range Forwarding Table
FTP[TCP/21~21] to IP 192.168.1.2
FTP Range[TCP/55536~55543] to IP 192.168.1.2
Rsync UDP[UDP/873~873] to IP 192.168.1.2
Synology DS212 Nas with static IP 192.168.1.2
Each time a user connects to my ftp server, I get a lot of these errors.
This is just a small sample of the log
[HACK] SynFlooding Attack
IN=eth1 OUT=eth0 SRC=xx.xxx.xx.xxx DST=192.168.1.2 DMAC=e0:2f:6d:75:34:d9 SMAC=00:13:72:52:16:5c LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=16112 DF PROTO=TCP SPT=45496 DPT=21 WINDOW=8192 RES=0x00 SYN URGP=0
The same happens when an rsync backup is running on my DS212
2013-10-05, 12:11:15
IN=eth1 OUT=eth0 SRC=xx.xxx.xxx.xx DST=192.168.1.2 DMAC=e0:2f:6d:75:34:d9 SMAC=00:13:72:52:16:5c LEN=60 TOS=0x00 PREC=0x00 TTL=54 ID=42649 DF PROTO=TCP SPT=36846 DPT=873 WINDOW=5840 RES=0x00 SYN URGP=0
If more information is needed please let me know
Any ideas why this happens?
Martin
5 Replies 5
Marc Nagao
Martin,
If you haven't already, please contact support so we can take a look.
Appreciate it sir.
Marc
Hi Marc
I will do, thanks
martinmpet
Maybe a stupid question, how do I create a support ticket?
If I click on the link "contact us" then I chose
Open a Technical Support Request here
But it require the following as you can read
Your login ID is not set up to access the TAC Service Request Tool (TSRT).
To obtain access, add all of your Cisco service contract numbers to your profile by going to the
Cisco Profile Manager - Request to Insert Contracts
. If you are a Cisco Partner or a customer with a Service Access Management Administrator, please contact that resource to obtain access to your service contracts.  You may use the
Service Access Management Tool
to find your Service Access Management Administrator.
Unsure of your contract number? Your
Cisco Partner
, Reseller or Cisco Services representative can help provide a complete list of your service contracts.
The TAC Service Request Tool (TSRT) is designed to support contract-entitled services only at this time. For urgent issues or warranty service please contact the
Cisco Technical Assistance Center
via telephone.
See
Cisco Global Technical Services Quick Start Guide for additional assistance. Your login ID is not set up to access the TAC Service Request Tool (TSRT).
To obtain access, add all of your Cisco service contract numbers to your profile by going to the Cisco Profile Manager - Request to Insert Contracts. If you are a Cisco Partner or a customer with a Service Access Management Administrator, please contact that resource to obtain access to your service contracts.  You may use the Service Access Management Tool to find your Service Access Management Administrator.
Unsure of your contract number? Your Cisco Partner, Reseller or Cisco Services representative can help provide a complete list of your service contracts.
The TAC Service Request Tool (TSRT) is designed to support contract-entitled services only at this time. For urgent issues or warranty service please contact the Cisco Technical Assistance Center via telephone.
See Cisco Global Technical Services Quick Start Guide for additional assistance.
Hi Martin,
Since you are within warranty, the best way to open a case is to call the Small Business Support Center and speak with an engineer.  They will help you open a case.  The phone numbers in your area are located here: https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
Michiel Beenen
Level 3
Level 3
Best advice on this, disable SPI Firewall and DDOS prvention and this will be fixed.
In fact i also notice the router is a bit faster with those both disabled.
