RV320 Max WAN-LAN Throughput
ccreacoon
I have a RV320 here on a 500/500Mbit fiber line, and don't seem to get more than ~230Mbit througput.
If I connect the original modem from the provider, I get 500/500Mbit throughput.
Firewall is off while testing.
Does the RV320 not provide more throughput, or can it be a setting?
@Marty, I tried it but didn't matter in speed.
Tested serveral times with the Cisco (230Down/130Up) vs Arcadyan(480Down/480Up), but they stay the same no matter the settings.
Also tried to change the MTU, to see if that had any effect, only effect was that the WAN connection didn't work anymore
7 years later still no firmware update to bring the 900Mbit wan-lan performance.
I have 1Gbit/s cabel internet. with the ISP-Router a have ~980Mbit/s in Web-Speedtest, with the RV320 max is ~500Mbit/s on Wan-Port
