RV320 - Performance degraded when activating bandwidth management
skippyyyy
I am in the process of configuring the RV320. I have set up only 4 rules in the Bandwidth Management (48-96 kb/s for SIP and RTP for my voip phone) and that severely impacted the network performance :
Before applying bandwidth management :
  • Ping = 12ms
  • down = 13.1 Mbps
  • up = 0.92 Mbps
After applying Bandwidth Management :
  • Ping = 73ms
  • down = 8.8 Mbps
  • up = 0.35 Mbps
That's a huge impact for just adding such a simple rule ! Is this an expected behaviour on this router ?
10 Replies 10
Kremena Ivanova
Can you share more details about your configuration.
What is the Upstream and Downstream you've configured? For the rules have you tried with Priority as well, not only Rate control? Did you configured the rules for both Directions - Down and Up?
Kremena
The upstream and downstream is set to the same value : min 48 Kbps max 96 Kbps for ports 5060-5090 and 30000-30100
For the rules I indeed tried priority mode first. The result was catastrophic : traffic was even worst with ping over 100 and upload speed close to 0 !
Concerning the configuration :
 - the router is currently connected to one wan only but is configured to use wan 1 and wan 2 because we will have a second Internet connection soon
 - there is no vpn setup
 - firewall : I disabled SPI
 - I have 3 vlan : two for workstations, one solely for the voip phone
Thank you.
Did you configure Upstream/ Downstream (Max Bandwidth Provided by ISP)? The router is using these values to calculate how much bandwitch to reserve for the services in the rules and how much will have for the rest of the trafic.
By default these values are on 10000Kbps. Which means that after excluding the rate control max value (2 times 96), your bandwidth for the rest of the trafic should be max 9, something Mbps.
If you havn't done that, please try to configure the max bandwidth from the ISP and share the speedtest result.
Kremena
Yes I had already set the max bandwidth provided by the ISP.
When plugged directly in the modem I get these speeds : up : 0.95 Mbps / down : 13.5 Mbps
I rounded these values in the router config to up: 900 Kbps / down : 13000 Kbps
The rate control I have set is very small : 96 Kbps x 2 = 192. That should leave 900-192 = 708 Kbps up and 13000-192=12808 down. Unfortunately that's not the case...
I know I'm replying to an old thread but I have experienced the same result when I configure bandwidth management on the RV320.  I called Cisco support and found out that this is a limitation of the RV320:
"High Priority domain shares about 60% of the bandwidth, Low Priority domain shares 10% and Middle Priority (outside rules) shares 30%." These values are hardcoded and cannot be manipulated.
I'm also experiencing the same issue with an RV320 too.
What do you mean by "limitation" ?
Is it more a bandwidth "reservation" ? not a real "QOS functionality" ?
Regards.
The above tests were carried on our backup internet line. Today our main line (fiber connection) is working again after being down for two weeks.
The results are even more impressingly disappointing :
 - Straight out of the modem we get roughly 300Mbps up and down
 - Going through the RV320 with bandwidth management rules disabled I get roughly 130 Mbps up and down !
 - Then if enable the rules, it falls to to 80 Mbps !!
These numbers are very, very far from the advertised throughput.
You can try testing with MTU size and change the negotiation of both ports WAN and LAN from Auto to manual. Try with symetric configuration - 100 WAN and 100 LAN, or if both connections are on gigabit 1000/1000.
But in your case, I would suggest to call the support line and an engineer to investigate more closely the configuration, in order to find a solution.
Hereby the contacts:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Kremena
Dear, I have problem with RV325, my connection is 1Giga fiber. When I turn off the RV and turn it on again, the speed hits + or - 810Mbps down and 795Mbps up, after a few minutes of use the speed drops to 80Mbps down and 42Mbps up.
I questioned the ISP and it proved it has no error. It is regrettable to see several reports, especially for a differentiated equipment like this. Does anyone have any solution to this problem.
I have the same problem. RV325 was working fine on single WAN (throughout of 500~600Mbps). When I have plugged-in and configured WAN2, both connections dropped to <95Mbps. Afterwards, when I have unplugged WAN2, sanitized config, speed for WAN1 still <95Mbps. Straight from the modem I have 940 Mbps. Bandwidth management was set at default (10000 kbps up/down) all the time (when it was working at 600 Mbps and when it was working at <95 Mbps). Even when upped to 1000000 kbps there was no change.
Thank you for your help!
