RV320 port redirection?
rob
I have an RV320 set up for a customer but I guess I got the instructions wrong for port forwarding.  What they want, and what the old router did was:
External port 45069 should be mapped to Internal port 5069 for IP 192.168.0.8
External port 44222 should be mapped to Internal port 22 for IP 192.168.0.8
Port forwarding did not work.  How do I do this?  I have attached a snapshot from the old router.
Thanks in advance.
Glenn Martin
please take alook at the document: Port Forwarding and Port Triggering on RV320/RV325
let me know if this helps.
Glenn, thanks for the reply.  The solution was to use Port Address Translation and to be sure not to also be using Port Forwarding as one seems to cancel the other.
Cheers!
As far as I can see, this solution only works for inbound connections?
Is there a work around for outbound?
Best regards
  Jan
