RV320 VPN is not routing randomly VPN gateway to gateway
mehdi77680
I have 2 rv320 router in differents site.
version 1.3.1.10 firmware
I have 2 wan connections in each site connected in each router
I have actived the load balancing in actif/actif mode.
I have created a VPN with the two router in gateway to gateway mode.
VPN has not be routed the flux randomly after 2 or 3 or 7 day.
when you check the status of the VPN tunnel , the status is connected from the two site
The GUI is up and all other flux has been routed .
After a reboot of the routers , the VPN come back Up and running.
Have you the same problem with the firmware version ?
Did we need to add static route on the router for the VPN subnet or is it automatic when you create the tunnel with the wizard ??
Jorge Obregon
I hope you are doing well. In case you are still having the issue I would advise you to do a downgrade to 1.2.1.14 first  since that firmware version 1.3.1.10 had some issue that are being fixed this is to avoid any issues relating the firmware release.
