I have two offices connected by cisco rv320 , latest firmware V. 1.3.1.12. using a VPN Tunnel.
The internet connections at both offices are Fibernet 200Mbps down/20Mbps up
Logging on the domain from the remote office takes too long, accessing the database server is also slow.
Simple file copy from local to remote office seems to suggest that the VPN only allows for a (fluctuating) 2Mbps transfer at most.
I disabled the firewall, there are no bandwidth rules.
What can I do to improve the situation?
best regards
glenn
