RV320 where is to find a NSD switch for USB Ports
bglatz001
i have a RV 320 FW: 1.1.1.1.19 I try to bring a USB Dongle to work on USB1.
In the USB failover settings i could change the settings from 3g/4g Primary Mode to deactivated and save it.
But now whenever i want change in another mode like Failover/Hot or Failover/cold or Primary Mode the Router Reports a error
what says: Please activate NSD for USB Port ..... but i cant find in the Router Menu a switch for the NSD to USB.
does someone know where it is to find ?
Thank you
Kremena Ivanova
I see that you've opened a ticket with the Support for this, so I will provide the answer for the audience.
In order not to see this message, network service detection on both WAN1 and WAN2 should be checked. There is no NSD for the USB port. I see that the message is misleading, pointing to the USB interface. It is addressed to be corrected in future.
Kremena
Kremena Ivanova
Kremena
 i haved answer from support too and saw that both WAN MUST be checked for NSD that its working.
Cause for that confusion is  that missleading message and a very low manual of this Router.
Thanks for your answer :-)
