12-17-2018 05:16 AM
Hi All. Really basic setup here.
RV325 ------VLAN A
B C
In a test environment trying to setup new office network with goal of
3 - VLAN (A, B, C)
A 192.168.1.1
B 192.168.2.1
C 192.168.3.1
Want Hosts on A to communicate with B and vice versa
Want C to be completely isolated
I dont have another switch in place. I was under the impression that the RV325 would do exactly what I am asking for here.
From a fresh factory reset
1. Basic setup with passwords etc
2. Enable VLAN and InterVLAN routing in Port Management
3. Connect desktop to port 2 and configure static IP on VLAN B
4. From desktop on port 1 with DHCP for VLAN A, attempt ping of Host on port 2. None received.
This seems like it should be very simple yet I am having a problem with this. Maybe its just not possible with equipment. My hunch is I may need a smart switch to give the rv325 a routing only job instead of a layer 3? I've tried this more than a few times after resetting to factory.
Thank you for taking the time
~Scott
Solved! Go to Solution.
12-17-2018 08:04 PM
12-17-2018 06:14 AM
12-17-2018 07:58 AM
12-17-2018 08:26 AM
12-17-2018 08:52 AM
12-17-2018 08:04 PM
12-18-2018 08:18 PM
Thank you for all your help!
