RV325 Easy VPN does not work if Split channel is selected
r.odstrcil
Hello!
I have my RV325 Router configured to use Easy VPN connection from outside.
My setting for Tunnel mode is Full Channel. Connection from Android mobile works.
But it is connected to default VLAN1.
When I change Tunnel mode setting to Split channel, Android device cannot connect.
It does not matter if I set it to VLAN1 or the other desired one.
Does somebody know, where is the issue?
Thanks!
6 Replies 6
balaji.bandi
When you configure Split tunnel you can only able to access the rest of the required resources of the internet use your DSL, here is the example, hope you followed same guide:
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb4296-configure-easy-client-to-gateway-virtual-private-network-vpn.html
when it is not connecting what Logs you see on RV side and what is the error you get in device ?
BB
I followed that configuration guide.
My Android phone says that connection was unsuccessful.
0 connection tunnels connected in the Router.
Router log is:
Dec 17 21:37:58 2020 Name VPN Log: [grpips1][2] xx.xx.4.0/24=== ...yyy.yyy.yyy.yyy===? #34: [Tunnel Authorize Fail] RC5_R16_B64_CBC is not enabled for this connection.  Attribute OAKLEY_HASH_ALGORITHM
Dec 17 21:37:58 2020 Name VPN Log: [grpips1][2] xx.xx.4.0/24=== ...yyy.yyy.yyy.yyy===? #34: [Tunnel Authorize Fail] peer proposed key length not enabled for this connection.  Attribute OAKLEY_KEY_LENGTH
Dec 17 21:37:58 2020 Name VPN Log: [grpips1][2] xx.xx.4.0/24=== ...yyy.yyy.yyy.yyy===? #34: [Tunnel Authorize Fail] received Hash Payload does not match computed value
Dec 17 21:37:58 2020 Name VPN Log: [grpips1][2] xx.xx.4.0/24=== ...yyy.yyy.yyy.yyy===? #34: [Tunnel Established] ISAKMP SA established
Dec 17 21:37:58 2020 Name VPN Log: [grpips1][2] xx.xx.4.0/24=== ...yyy.yyy.yyy.yyy===? #34: [Tunnel Established] received XAUTH ack, established
Dec 17 21:37:58 2020 Name VPN Log: [grpips1][2] xx.xx.4.0/24=== ...yyy.yyy.yyy.yyy===172.16.100.102/32 #34: [Tunnel Established] sent ModeCfg reply, established
suggestions :
1. After changing the config reboot and try.
2. check is this bug you may be encountering :
https://community.cisco.com/t5/small-business-routers/rv325-login-issue-after-upgrading-to-1-4-2-15/td-p/3185089/page/2
BB
Thank you, but unfortunatelly I did not find working answer there.
balaji.bandi
after change the config have you rebooted and tested ?
BB
I activated Restart (reboot) from web interface. After that it was the same = no sccess in Split mode.
Btw: I have to say that such reboot took incredibly short time (1 - 2 s) and I did not have to login again. Is it ok or is there something wrong?
