07-25-2018 04:07 AM
Greetings!
I'm using a RV325 Router with 20 days of use. The device has stopped and the PWR and VPN lights flash and the DIAG, USB1 and USB2 lights are on, I can not reset the machine. Is there any way to solve or is this a problem for RMA?
07-26-2018 01:28 PM
Hello Botelho,
I am sorry you are having this inconvenience with the router, but let me give you some ideas about how to solve this.
You will need to do a firmware recovery.
https://software.cisco.com/download/home/284005929/type/282465789/release/1.4.2.19?i=!pp
* screenshot attached
6. if this does not work you will need to do a Factory reset prior to the steps above (keep in mind that you lose the configuration on the device)
Step 1. Power off the RV325.
Step 2. Hold in the "RESET" button and then turn on the router.
Step 3. Wait for few seconds till you have Led DIAG in Solid RED, Led Power and VPN Solid Green .
Step 4. Release the reset button.
If this steps are still not working please give us a call to 1866-606-1866 so we can open a case and help you with this and we will determine if this is a hardware failure or not.
Thank you for contacting cisco support community.
