RV325 - VPN does not work anymore after first restart
PetruSlupa84072
I have reconfigured the router many times and everything works fine until first reboot. VPN is no longer working no matter what I am trying.
Error in log is: Tunnel Authorize Fail - no connection has been authorized with  policy=AGGRESSIVE+XAUTHPSK+XAUTHSERVER
VPN is configured as EasyVPN with full tunnel.
If I do factory default and configure again, VPN works again until first reboot.
Firmware version is 1.4.2.22
Any idea?
Many thanks.
Hi all,
I have no contract for support, therefore I got no help.
Anyhow, I have downgrade the firmware to 1.2.1.14 and evrything works fine. I can connect to VPN after the restart, I have checked also with IPhone.
Firmware version 1.3.2.02 does not work either. I do not know if one of the version 1.4.x.x will work, but I will not try anymore.
Solution: Downgrade to 1.2.1.14 if you want EasyVPN to work.
5 Replies 5
balaji.bandi
looks odd as per the description you have mentioned here.
please do contact SMB support, they can investigate for you.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
BB
Thanks for hint.
If I force another save on WAN1 then I can have VPN for 10-15 seconds. No VPN connection after that.
Could be related with "Connected(Inactive)" state of WAN1?
Thanks.
Hi all,
seanhaughey007
I too had this issue.
Nothing I did, including rebuild from backup, resolved my issue.
I deleted all gateway - gateway VPN's all to no avail.
I was running the latest firmware 1.5.1.11.
What I did to get it working was downgrade to 1.4, then upgrade back to 1.5.
After that, all VPN's connected
PetruSlupa84072
No,chance. I have tried the same and it does not work.
I have now 1.5.1.13 firmware and I switched to OpenVPN. EasyVPN configuration does not work for firmware 1.5.1.13 when you use an Iphone Xs to connect to router.
