03-27-2018 11:39 PM - edited 03-21-2019 11:07 AM
After update to 1.0.1.18 I am not able log to GUI.
Router works, but when I want log in and configure something, the web does not work with browser error ERR_CONNECTION_TIMED_OUT.
Update: I am able login to VLAN1 IP address when I connect through VLAN1 untagged port. Other IP address which works before does not work now, maybe some kind of security.
Solved! Go to Solution.
04-03-2018 06:41 AM
If you can get in from the other VLAN;
In the router GUI, go to LAN, VLAN Settings.
Check the VLAN you are having problems with, click Edit, and enable Device Management.
I just had to do the same thing after upgrading my router this morning to 1.0.1.18.
03-31-2018 05:29 AM
Hi Viktor,
Issue will get resolve by performing factory default reset on the RV340 router.
If you are still facing the same problem with the latest firmware version 1.0.1.18 of RV340 router, I suggest you to use the older firmware version and check whether the issue is same or not.
04-01-2018 09:51 AM
I have this problem too. I forced the RV340 to go back to 1.0.1.17 by switching it off, then on for 30 seconds, off ... (5 times, see manual). After that the router uses 1.0.1.17 and I was able to login again.
Configured 1 port untagged in VLAN1, saved and backup config to pc. Reboot to 1.0.1.18 factory default.
Restored saved config. Reboot again. Only access to GUI via untagged port in VLAN1.
I think something is wrong with 1.1.0.18 firmware at this point.
04-03-2018 06:41 AM
04-03-2018 09:53 AM
Thank you very much.
I set the "device management" option at the correct VLAN as you mentioned and I can reach the GUI again.
