RV340 First connection
Hey, I'm new in the world of cisco routers, I just bought a 2nd handed RV340 for load balancing and VPN, I connected my ISP provider to WAN 1 port and my PC to any LAN port to start the basic configuration, but my PC doesn't receive a DHCP IP from the RV340, I just receive a random IP, I tried factory reset with no good results.
Any suggestions of what can I do?
balaji.bandi
basically these device do not have any Cli access to post show run.
Steps :
1. reset to factory
RESET—Reboot or reboot and restore defaults:
• To reboot the unit and retain the current configuration, press and hold
RESET for at least 3, but no more than 10 seconds, by using a paper clip
or a pen tip.
• To reboot the unit and restore the factory default settings, press and
hold in the RESET button for more than 10 seconds. Changes made to
the original configuration of your device are lost.
2. then do the quick setup :
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/RV340/Quick_start/EN/rv340_qsg_en.pdf
BB
chesterr
Could you show running-config of RV340 ?
balaji.bandi
Steps :
1. reset to factory
or a pen tip.
BB
Hey! I tried many times to do the factory reset, but no good results, then I thought it might need more time than 10 seconds, I leave the button pressed until the VPN Led turned red, unplug and plug the power and it worked! I am now able to access my RV340 GUI.
