RV340 Static routes between VLANs
dsjordan
Beginner
Beginner
I'm trying to add routing between a few VLANs on our existing RV340 router.  Attached are pics of the settings of the VLANs and the static routes.  The goal is to have VLANs 10-15 be able to communicate with each other, but I started out with 10-12 and they aren't able to ping each other.  What am I doing wrong?
Thanks for any advice you can provide!
Dave
You need to explain more - PC in VLAN 10 not able to access PC in VLAN 12 ?
But PC in VLAN 10 can able to ping Gateway of VLAN 10 and 12 - ( same PC in VLAN 12 able ping gateway and VLAN 10 Gateway ?
if the issue between PC have you check the PC FW
have you enable inter-vlan routing when you created VLAN check below guide :
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/1393-Inter-VLAN-Routing-with-Targeted-ACL-Restrictions.html
BB
marce1000
          - You have no pics attached ,
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
BB
