RV340 with USB Tethering
Unmesh Joshi
HI,
I am trying to connect a HUAWEI 34666RBC to the USB port.  It works for some time, but then gets disconnected, and router just hangs (probably 100% CPU), and needs a restart.
Is this a bug in new firmware or USB tethering does not work with RV340?
As a follow up question. Is it possible to have a Android phone in USB tethering mode, connected to the USB port for RV340?
5 Replies 5
marce1000
        - Check the logs when this happens>
 M.
the logs say USB disconnected.. and then the router just hangs.. so I need to restart it.
Does USB work fine for you folks?
balaji.bandi
as per the feedback here, none was report as mentioned, worth doing syslog what is going on background when it hangs.
BB
Martin Aleksandrov
Hello Unmesh,
Here is the link with supported 3G/4G USB dongles. The one you are using is not listed amongst the supported models though.
Also please read the statement "Important Notes" of that same document. We will no longer support any new USB dongles.
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/RV340/USB_compatibility_matrix/RV340_compatibility_matrix.pdf
Martin
Thanks.. Looks like Huawei E3372 is supported.
Anyone using this model successfully? I can buy that one.
